Excentric turning and milling
Technical data
● available
5-axis machining for maximum flexibility thanks to a swiveling rotary table supported on both sides for components up to ø840 x 770 mm and 600 kg
CNC Universal Milling Machine with swivel rotary table
High-precision, 5-axis control vertical machining center that uses DDM on rotary axes
The next Era of Metal Additive Manufacturing!
The medium size turning machine with two turrets
One Y axis – up to 36 tool positions
High performance & precise universal milling center for workpieces up to Ø630 x 450 mm and 300 kg on 6.4 m²
High performance & precise universal milling center for parts up to D800 x 450 mm and 350 kg!
The entry machine for 5-axis simultaneous machining
Additional exclusive content:
